DLC not working
DLC not working
I'm not able to connect my laptop to my PCm via the DLC in my 94 camaro Z28. I have a scanmaster connected with a disconnect switch installed so it wouldn't interfere with the usage of the DLC. I've programmed my car several times in the past using Tunercats and the same ALDL cable I'm currently using. Tunercats will not connect to my PCM and I keep getting the message "Incorrect Response from PCM". BUT, when I switch on my scanmaster and try to read PCM it starts like it's gonna read then pops another error message; obviously due to the scanmaster interfering which I undeerstand.
I currently do have my cig/horn fuse out, but I thought that shouldn't matter on a 94. Am I correct?
I'm stomped. Any help would be appreciated.
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
re: DLC not working
What kind of cable? Who was the manufacturer? It sounds like the driver for the able is incorrect and that could occur if the pc automatically downloaded a new one. Or the cable is defective, it happens.
Make sure the pins in the DLC are all in place and one has not pushed out.
If all else fails, try to rollback the driver to the last one used.
re: DLC not working
1994formy
06-02-2011 07:19 AM
Bawls
20
09-06-2005 02:29 PM
