Racetronix 32lbs rate specs
Old Aug 18, 2007 | 10:14 AM
always faster's Avatar
Im playing with my tunercat and i ve checked my basic tune for my injectors:
Racetronix 32lbs(Delphi 17208a)
Static Flow Rate @ 43.5PSI (300kPa) = 31.6 lb/hr = 332cc = 239g/m
Dynamic Flow Rate @ 43.5PSI (300kPa) = 6.68 gm/pulse - 2.5ms pulse width and 10ms repetition rate
In my Tunercat mail order tune(lt4) files i got:
Flow rate: 31.73 lbs/hr
Display flow rate: 3.81 Gl/Hr
Am i wrong if i think that i should have 31.6 of flow rate since those injectors are rated at the same psi of a f-body regulator?
And what about the display flow rate?
I would like to understand all this also,so with your answer a quick explanation would be appreciated
Old Aug 18, 2007 | 12:32 PM
Just wanted to know if im correct.
32lbs divided by 24lbs give : 1.3333333
So i take my basic 3.81gl/hr and multiply it by the 1.333333
And that gave me 5.08
So i should put:
31.6 lbs/hr in the flow rate
and
5.08gl/hr in the display flow rate
Right?
Old Aug 19, 2007 | 07:54 AM
VinceTrifecta's Avatar
The display rate is only for Corvettes that had an estimated MPG calculator.
As for the flow rate, looks good on paper, provided the ratings from RaceTronix are accurate.
Old Aug 25, 2007 | 08:38 AM
C Man's Avatar
Just checked a few stock programs... each one shows 24.91 Injector Flow Rate for the stock injectors.
I wonder if that would affect your calculations.
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
form94
Sep 23, 2015 07:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
