Pretty sure I cooked the ECM - TunerCats
connected, downloaded the ECM just fine.
saved the download so I had a current 'stock' copy.
opened new calibration file.
chose program ECM, saw it Erasing Flash, then this error. (see attached)
now when I cycle power, the fans come on and stay on until I turn the key off...
So, someone tell me I've cooked it so I can start hunting for a new one... OR if there is a slight possibility I can resurrect this... please please please tell me.
Prominent Member
Re: Pretty sure I cooked the ECM - TunerCats
I am not very familiar with programming the pcm. I have done this a total of TWO times only just to see how it was done. So I can't really offer expert help.
That being said, I would download WinFlash (if that is not what your are using already) and see if it can read the pcm.
TunerCat
As far as I know, if the pcm is "bricked", there are only two options: 1) Buy another pcm or 2) get someone to "unbrick it" by replacing the soldered-in memory chips inside. Either way is probably at least $100. And no, I don't know who to recommend.
TunerCat
Prominent Member
If you are good with electronics repair this may be of interest.
How to fix the PCM Flash Memory
LT1 ECM 16188051 repair source?
As I understand it, you would need
1) the programmer ( a TL866A at $50 should work)
2) two memory chips and sockets (about $10) , and
3) some fine-pitch soldering and un-soldering skills.
Thank you both.
I've went ahead an bought I new PCM from another member that already has the sockets installed... I'm now looking for more chips in the event I do this once again.
Thank you both for the assistance... I guess another week of waiting to hear what this sounds like is what is required...
