PE table for stock car
i was looking and couldnt find anything. so figured id ask..
does anybody have a good "PE Vs. RPM" for a stock car w/ maybe the "free" mods??
i just want to see if it helps and really dont have the $ for a full tune and have tunercat..
thanks
thanks
ok i think i have something here. i found a few dyno sheets of stock cars (94s and 95s) and the seem to hit peak TQ @ around 4500 rpm.
so w/ the TunerCat AFR "WOT AFR = 14.7 / (1 + %Change vs Cool/100 + %Change vs RPM/100)"
and excel i ran some numbers and got this.. i want 12.6:1 to peak TQ and 12.8:1 after that.
so here is the Calculated PE Table..
RPM %Change AFR
400 0.8 12.59
800 0.8 12.59
1200 0.8 12.59
1600 0.8 12.59
2000 0.8 12.59
2400 0.8 12.59
2800 0.8 12.59
3200 0.8 12.59
3600 0.8 12.59
4000 0.8 12.59
4400 0.8 12.59
4800 -1.2 12.80
5200 -1.2 12.80
5600 -1.2 12.80
6000 -1.2 12.80
6400 -1.2 12.80
6800 2.7 12.38
so would it be safe/ok to use the values above on a stock car??
RPM %Change AFR
400 0.8 12.59
800 0.8 12.59
1200 0.8 12.59
1600 0.8 12.59
2000 0.8 12.59
2400 0.8 12.59
2800 0.8 12.59
3200 0.8 12.59
3600 0.8 12.59
4000 0.8 12.59
4400 0.8 12.59
4800 -1.2 12.80
5200 -1.2 12.80
5600 -1.2 12.80
6000 -1.2 12.80
6400 -1.2 12.80
6800 2.7 12.38
However, unless you either calibrate your MAF or dyno tune with a wideband, you have no idea if these numbers are correct when you in fact go into PE mode.
Ben
Brandon Wittmer
Dec 20, 2014 09:51 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
