OBD 1 swap for 97 Z28....
....what do I need besides the computer itself? Do I need a harness, any special connectors, etc...or is this pretty much a plug and play swap?
Also, do I want a PCM from a '94 or '95 car, or are they both completely identical? |
Anyone know anything about this? Or is this more of an "LT1 tech" question?
The PCMs for a 94/95 are identical except the program in them. You will want to run a 95 program.
If you change the knock sensor to a 95 one and run an OBDI PCM with a 95 tune on it, that's all you will need. |
