Need an ABS code scanner. Monitor 4000e?
My ABS light has been on since I bought my '95 Z28. The symptoms point to a bad wheel sensor, but I don't know which.
A Monitor 4000e has poped up in my local classifieds, and I believe it was used at my local GM dealer. I can't find any information on this reader, but I know that most OBDI readers will read engine codes but not ABS. I'm just wondering if anyone knows if this reader will work, and if not what reader I should look for. |
Re: Need an ABS code scanner. Monitor 4000e?
Look at the sticky for the free 94/95 scanning software. It's at the top of this forum. You'll need a cable to use it. It will scan abs codes.
Couldn't find much info on it, but what info I found didn't mention ABS.
Originally Posted by rngilliland
(Post 6946891)
I didn't realize how far you guys have come since the last time I looked into building a cable! I think I will build the cable, but also pick up the OTC scanner if I can get it for a good price. I'll post an update in this thread after I try to scan the ABS codes. |
