97 LT1 Pcm in 95?
Re: 97 LT1 Pcm in 95?
The 97 PCM will work with the 95 engine. You will have unused connections that will produce codes, unless they are tuned out - after-cat O2 sensors, crankshaft position sensor, EVAP vacuum detection switch come to mind. The 97 PCM will require you to install a (100Kohm) 96/97 knock sensor in the 95 (which has a 4.4Kohm sensor).
4th Gen LT1 F-body Tech Articles
May be some issues with wiring the DLC connector - not sure.
http://shbox.com/1/DLC_wiring.jpg
What the 97 PCM is not compatible with, if your 95 has an auto trans, is the 95 version of the 4L60E. While both use a pulse width modulated converter lockup, the internal components are not compatible.
4L60E year differences and interchanges.
Good chart of year-to-year differences from Shoebox, who also supplied the first two links above:
http://shbox.com/1/4th_gen_f-body_ye...onversions.pdf
