Datalog help needed
I'm trying to record a datalog but when I try to record it says PCM not found. (Datamaster)
Also when I try to communicate with Winflash it says no response from PCM. I checked both wires from the PCM to the data port under dash for continuity and they are good. About a month ago I programmed my tune with Winflash without any problems. I also checked the ALDL cable and it's ok. I'm stumped and need help. Car is a 95 Z28 lt1 Mark |
Re: Datalog help needed
While I review and interpret Datamaster files all the time, I have no experience in actually running the system - I ditched the stock PCM 14 years ago. But based on previous posts, it sound like you may have a comm port error.
Their Datamaster manual may address this, but I just looked a the TTS Power Systems website, and when I clicked on the link to download the .pdf file of the manual, I got an error message. Were you able to download the manual? GaryDoug is the expert.... might want to try sending him a PM. |
Thanks, Fred I'll pm Gary
Originally Posted by msize
(Post 6965705)
BTW, the email notifications for me rarely work here, so I may not notice any PM's, although you can try. Also, here is the correct link to the manual: http://www.ttspowersystems.com/downl...32man_v400.pdf |
It started working again. Still don't know what the problem was but it's working for now.
| All times are GMT -5. The time now is 08:16 AM. |
