Anyone know the pinout for the opti harness???
Thats helps but would you also know where they end up at the pcm. I'm wanting to measure the resistance from the connector thats plugs into the opti to where they end up at the PCM.
Thanks,
Rob
Thanks,
Rob
pcm
low res signal / red/black--------------- pcm 2
reference low pink/black---------------- pcm 3
ign voltage red ------------------------- pcm 14
high res signal yellow ------------------pcm20
i am not sure which plug on the pcm they are in it should be easy to see.
