ALDL OBDII Connector Pinout
I am working on a 96 LT1 Engine swap and need some information as to how to wire the ALDL OBDII diagnostic port to the PCM.
For now I know the following: There are six connections to be made: pin 2 pin 4 Ground pin 5 Ground pin 6 pin 9 pin 16 Battery + I need the ECM connector reference for pins No 2, 6 & 9 Any help greatly appreciated RG |
Found it!
As always Shoebox comes up tp the rescue. Should have done a search before posting. http://shbox.com/1/1996_ec_02_DLC.jpg |
FYI on my conversion, I have an OBD II port but the PCM is OBD I. I ended up only using the serial data port and ground to read and program. Not sure if OBD II PCMs will be the same.
