95 lt1 fuel adjustment
ok guy i had the car dynoed today and it wasnt as good as i wanted but not to bad, the air fuel ratio was 11.2 witch is bad. on the tuner cat program what should i adjust and how much to get it to come closer to 12.8-13.2 ?????? any help would be appriciated
Those are the AFR numbers I'm looking for:lol
I don't know Tunercat but, if it has a PE table vs RPM. I would subract about 18% from those numbers in the RPM range where you want the change to get you where you want.
jb4xx
Feb 2, 2015 10:00 PM
Jul 4, 2005 05:00 PM
