Tremec 5 Speed
Hi, i was wondering if a Tremec 5 Speed would work in a 71 camaro with a carbed engine. I have never tried mixing new and old stuff together so im not sure. If it does, would I need any other things besides the normal parts for an auto to standard conversion? (I have a TH-350 in there now, and a 350 for the engine). I was originally just going to find a good muncie 4-speed but I found a good deal on a Tremec out of a 99' Cobra. Thanks for the help. Technology owns me.
I'm having a Tremec TKO-500 installed in my kid's blue 67 SS clone as we speak. The guy doing the install for me recently installed one in a 70 Chevelle behind a GM 502 crate motor. Mine was purchased as a complete kit including new cross member, driveshaft, bell housing, clutch, shifterm etc. There are several places that sell kits out there, including ones to convert automatics to 5 speeds. Here's a great place to start... http://www.5speedtransmissions.com
Not to jack your thread but does anyone know if the t5 will bolt up to a pontiac 400 or is the bolt pattern different?
Re: Tremec 5 Speed
T5 would grenade shortly after being put behind a Pontiac 400. T5s were only ever rated at 300 ft lbs.
The Tremec TKO would survive nicely. I'm pretty sure it'll work, too. You'll just need a BOP bellhousing, instead of a Chevy style. |
Re: Tremec 5 Speed
| All times are GMT -5. The time now is 08:40 AM. |
