Sluggish when Hot??
Okay, this might be easy for someone but for me its not. I have a Holley 600cfm 4160 carb on a rebuilt 350 motor. I can start cold and drive the car with no problems. But if I drive the car for a while, then turn it off, then crank it up again after 30 minutes or so of sitting there the motor kinda gags when I give it the gas. But after about 5 minutes its fine. This only happens after I start the already warmed up motor. Ive changed my power valve and that didnt help. I adjusted my rich/lean mix and this didnt help either. Ive also adjusted my timing. It almost seems like its getting to much gas after sitting there for a while after Ive already driven it. But if I waite until the car is cool to start it, its fine! This doesnt make any sense?
Originally posted by jg95z28
Manual choke or electric on the carb?
Originally posted by silvertripper
Electric Choke... and I've adjusted the choke to about a 10% choke when cool... to the point that I might as well take it off completely.
u just have to keep ur rpms up a weeee bit when its warming up on a cold morning.
Originally posted by kacy
what about the bowls leaking and flooding the motor and after it sits for a long peroid it will start again
Also, I forgot to mention that every now and then, when Im driving and I decelerate and then accelerate quickly (like going around a slow driver), it will caugh up..... acts like its gagging for a sec, and then its fine.
Re: Sluggish when Hot??
Okay, I already have a spacer under the carb. But it does feel like its getting too much gas.... or not enough. Im going to try and adjust the air/fuel and see if it helps.
I'll have to check this in a few of weeks guys, my band is flying to Boston to record an album. I'll get this thread going again when... or if.... I return. Wish us luck!
okay, just got back about a week ago! I took some $$$$ and baught a 750 carb w/vacuum sec. This seemes to have solved my problems. I think I might have been starving my engine of gas. My car runs AWSOME now... the best it ever has run thanks to the carb swap. I guess this is let anyone know who might have had the same problems that I did with a small carb, maybe going to a larger carb will to the trick?
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
