miss at 2800
Old Jun 28, 2004 | 08:19 PM
scarface846's Avatar
miss at 2800
i got another 79 camaro a month ago and got on the road and it have a miss and a loss of power at anything above 2800, it has a fresh mild 355, supercoil, stock hei, delco plugs, 045 gap, i dont know what else to look for, i have a new roter cap in it, i just want to be able to floor it without popping and snapping, thanks
Old Jun 29, 2004 | 12:03 PM
angel71rs's Avatar
Might be a fuel problem, either a plugged filter, kinked line, collapsed pickup sock in the tank, or a weak pump. I've also seen on Holleys where the rear float was set way low and it caused a similar problem. Also a piece of trash plugging up a main jet (primary or secondary) can make for rough running above 2,000 rpm.
Does it do it when you rev it in park/neutral or only in gear? If in gear (under load), it tends to say it's a fuel problem. If it does it in neutral too, then it points to ignition.
Old Jun 29, 2004 | 02:17 PM
it dosent do it at idle, i guess i may need a new carb, more like a 650 now it has a 750
Old Jun 29, 2004 | 08:45 PM
angel71rs's Avatar
No need to toss the carb, rebuild it if it is the problem. But check the other possibilities first.
Old Jun 29, 2004 | 09:49 PM
spinout's Avatar
how old are the plug wires if there is to much resistance in them they will cause a problem under load or look at modual in destributer and see if the 2 wires that conect to the modual arent damadged
Old Jul 1, 2004 | 11:00 AM
im getting a new set of wires today and getting my supercoil checked because its pretty old, i hope that solves the problem, thanks
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
Z28ELECTRICIAN
Oct 19, 2015 06:36 AM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Ks0209
Oct 1, 2015 07:32 AM
