gen 1 motor???
Old Jul 6, 2004 | 12:17 AM
TheBeast_93LT1's Avatar
gen 1 motor???
what are the specs on a gen 1 350 motor? does anyone have a gen 1 383? how are these motors performance wise as well as street wise? how could i put it in my 93' z-28? thanks.
-Daniel
Old Jul 6, 2004 | 09:39 AM
hello??? does anyone in this forum know anything about my questions?
-Daniel
Old Jul 6, 2004 | 12:16 PM
BamaZ28's Avatar
This forum moves along slowly, if you don't get anything here, try www.nastyz28.com
Old Jul 6, 2004 | 01:10 PM
angel71rs's Avatar
There are a bunch of variations on the G1 350, everything from lowly 2 barrels with <200hp to 370 hp LT-1's with forged internals. You can build any 350 to >400hp with cam/heads and still be streetable. There are new 383 cranks available at reasonable prices to drop into a 350, which is a good idea if an engine is to be built from scratch. Pistons for this combo available off the shelf.
As for switching for your LT1, it bolts in, but there are issues. Your engine is reverse cool, so radiator hose layout is different. also your engine has one piece seal on the crank, so you have to either get a later G1 350 engine (like off a third gen or C4 vette) that is one piece seal too, or if you go 383 route, order your crank w/one piece seal setup. but you still have to deal with flexplate/flywheel issues.
Going from a worn out high mileage G1 to a low miles LT1 makes sense for someone who wants to bolt in a modern FI engine, but I'm not sure that it would be worth the adaption hassles for you to go backwards.
If you are going to do a G1, might as well go for cubes. I have a 400 in my 71, and w/smog heads that flow like kaka compared to LT1 heads, stock converter and 3.42's have run a best of 13.7 at local 4,100 altitude track. Engine probably only makes 250 at the wheels with the smoggers, but the torque is excellent.
Old Jul 6, 2004 | 01:40 PM
i think i may just go the lt1 383 path. what do u guys think?
-Daniel
Old Jul 6, 2004 | 01:49 PM
is there a site like that for 4th gen camaros?
-Daniel
Old Jul 6, 2004 | 10:58 PM
angel71rs's Avatar
This board has an LT1 forum; I'm sure they can answer all your questions.
Old Jul 7, 2004 | 07:46 PM
kacy's Avatar
someone did a carbed engine in a 4th gen car ahd had issues with a air cleaner and being able to adjust the timing i the dist...stick with a lt1 its pretty much the same just has a few differences
Old Jul 8, 2004 | 05:48 PM
Capn Pete's Avatar
I had a carb'd (Gen-I) 383 in my old '81 Z28, and it kicked a$$! The heads were plain old "882" casting, 76cc smoggers, but I had a "decent" cam in it (.480"/.480" hydraulic) with headers and a good dual plane intake, and it was a monster on the street . I know I didn't race every fast car around, but the few that I did race against, I beat 'em. 383's are very torquey.
HOWEVER, while swapping a Gen-I in place of your current Gen-II LT1 shouldn't be too difficult, you'll lose out on the EFI which is actually a much better "street" oriented platform. And I hope you don't think like I used to, which is "old school is better.....carbs can out-perform EFI" because these new(er) Gen-II and Gen-III SBC's can put up a damn good fight against a heavily cammed Gen-I, yet they still pull over 20 MPG!!!
Just my $.02 here, but if you can afford to build your LT1 as a 383, then go that route, and keep the fuel injection.
Old Jul 14, 2004 | 06:00 PM
grygst76's Avatar
Or look into a 327 or 427.
Cam's maro
Jan 30, 2015 09:21 PM
ChrisFrez
Jan 18, 2015 08:05 AM
capebuf
Jan 13, 2015 07:22 PM
ChrisFrez
Dec 7, 2014 11:32 AM
