chevy 262
chevy 262
i recently got a chevy 262, it needs alot of work and its locked up but the cylinders have no wear on them at all, what should i do with it? lol should i rebuild and sell, rebuild and keep, or scrap it? lol
He never specified a V6 or a V8 and the question was asked in the classic tech section, not the V6 section. The V8 that was offered in 1975-76 was considered the 262. When GM offered the V6 with the same displacement, it was referred to as a 4.3L even though it is still 262 CID.
Even though the metric classifications of the newer engines have a common CID designation, they are referred by their metric size to eliminate confusion with the older models.
The V6 4.3L is a 5.7L with 2 cylinders chopped off. It has the same performance potential as the 5.7L but with less displacement. The 262 V8 however is one of the worst V8 engines GM even built.
I would agree with the other reply that a 283 is a better choice for a small v-8, but I've never heard of a 262 being built, and that would be so cool. They are the only SB to use a 3.1" stroke, so they aren't the "worst" v-8 made, (that would go to the 267, which uses the same stroke (3.48") as the 350 with a tiny 3.5" bore). If you're trying to build a decent gas mileage performer, why not try the 262? I have yet to see one built, just be real conservative on the cam.
PS: Sorry to any 267 fans out there, yes there are a few, and yes I have seen one run "respectably".
NewsBot
May 18, 2015 03:40 PM
NewsBot
May 16, 2015 04:20 PM
NewsBot
Mar 16, 2015 12:51 PM
CARiD
Jan 14, 2015 04:00 AM
formula79
18
Jul 1, 2002 02:39 PM
I dont recall a L6 262cid... 250cid and 292cid L6 yes...
