Blown carb gasket
Blown carb gasket
Well I took my camaro out for a spin around the block and I got on it a little bit and all of a sudden I started hearing this louding knocking sound. I was like sh*t!!!!!!!! I thought I threw a rod.... It was loud..... well I turned off the car and started it back up... heard it again... but when I gave it gas it went away so I knew it wasnt a rod....... the carb gasket in the front had been sucked in! now my question is, since this got sucked into the manifold will it be dangerous in away way? And what should I do about it? Never had this happen..... Thx
If u take your carb off u might be able to fish the pieces of the gasket out whith a piece of a coat hanger what type of carb are u running if u are using the paper type gasket u should find one that is thicker and make sure your carb is tightent to your specks good luck
hey hope you had some succes in geting the gasket out if you didnt get it with the coat hanger you might have to take the intake off to get the pieces i dont think it will hurt anything but its better to get a nother opinion i will check with my friend he will no for sure
1981 z28 350 bored 60 over flat top pistons 10 2 1 compresion 501 lift cam 202 valves
wiht 373 posi and t10 4 speed fffffffffast
