bigger wheels causing speedometer probs
Old Aug 6, 2003 | 10:50 AM
after the fire's Avatar
its a '68 and i have had it about 2 weeks. the speedometer seems to be 5mph slow (so when it says 40 im going about 45). i was thinking it has to do with not having stock wheels/tires. they are bigger than the stock ones. the car came with the wheels when i bought it. i was just wondering what to do to solve this?
i am going to buy a new speedo to mach the new tachometer. would this problem go away with a new guage?
Old Aug 6, 2003 | 12:48 PM
flaminchiten's Avatar
This problem will not go away with a new gauge. What you need to do is figure out how the wheel diameter affects your rear end gears. (ie. taller tires makes the gears numerically lower) there are calculators for this on the web. after you figure that out you will need to change the gear where the speedometer cable connects into the transmission. BTW if your original speedo is a 120 and you put in a 160 this will also affect the accuracy.
QuickSilver02
Apr 7, 2015 11:12 AM
jj_burchiel
Mar 21, 2015 12:51 AM
mattstrike
Mar 12, 2015 10:12 PM
squarehead
Nov 21, 2014 08:02 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
