Alt. Brackets for eletric water pump
Hey guys need a suggestion for a alternator and the brackets that would put the alternator low enough to clear my electric water pump. One that would not break the bank would be greatly appreciated as well
thanks yet again
thanks yet again
Depends upon if you are running a long water pump or short water pump crank pulley.
You can find a few steel versions on ePay for around $60 but they never show them in an engine compartment only on a bare engine out of the car so I don't know it it will fit a first gen.
March makes a mount set for about $140 that could work but I don't think it will clear the first gen Camaro a-arm or subframe with a big block like mine but it may work for a small block like yours.
I am building my own out of aluminum that will allow me to run the water pump with the electric drive or swap out the cogged pulley for a ribbed belt pulley so it can be crank driven too.
Blood type Z28
Apr 8, 2015 11:34 PM
