82 Engine And Trans Into a 79
Hello, New around here was trying to do some research i have a 82 Camaro V8 with no title and i have a 79 Camaro (No motor/Trans) i was hoping to take the motor/trans from the 82 and swap it into the 79.
Is this possible without major modification or no modification for that matter? Thanks in advance.:) |
Re: 82 Engine And Trans Into a 79
You would need to check is the trans. mount/cross member. Depending on the trans. And maybe check drive shaft length. No MAJOR mods. that I can think of, there's always minor stuff.
| All times are GMT -5. The time now is 10:19 AM. |
