73 firebird engine swap.
HI my uncle has a 73 firebird with a 350 olds motor with a turbo 350. He wants to know if the trans will work with a pontiac 400. Because the starter is on the left side on the 350 olds and on the new 400 motor he has the starter is on the right side.
Pontiac and Olds transmissions have the same pattern, known as the BOP (Buick, Olds, Pontiac), and they are interchangeable, except for stuff like the very early 389s that had the starter bolted to the bellhousing like the early SBCs.
I don't mind the TH350 behind the 400 in my 2nd gen. It works, gets the job done....
F'n1996Z28SS
Aug 23, 2023 11:19 PM
