350 heads
350 heads
i have a pair of heads for a 350 andi was wondering if they are special because they have the 13/16 spark plugs. All other 350 heads i have seen lately have the 5/8 plugs. the heads have to be reworked and i was wondering if they are worth the trouble.
thanks
thanks
All heads made before 69 had the large plugs. Corvette may have had big plugs after 68, not a vette guy so don't know for sure. They could be run of the mill heads, or from a performance application. One thing to be aware of is that Chevy did not start using hardened valve seats until 71, so there may be more valve seat wear. Check the casting number here for original application:
http://www.mortec.com/castnum.htm
Thanks,gottanother question... did the headsmade in the 67-69 range come stock with a 60 or 64cc only or did they also have the 76cc...i have heard that the 76cc came later for smog reasons...thanks again
Personally, I wouldn't mess with stock heads unless you're trying to keep that engine all original. There are too many alternatives that flow better than stock for a reasonable price.
stockssn2o
May 25, 2015 08:54 AM
Chris Anderson
Jan 27, 2015 08:30 AM
