2000 Camaro Monsoon to AUX adapter
Old 11-07-2017, 06:22 PM
Fat_OJ's Avatar
I just got a 2000 Camaro with the stock Monsoon head unit, and I began to look into adding an AUX input. I finally came upon the solution of using an adapter such as this one from Crutchfield, however the adapter is no longer available. Does anyone know of a comparable adapter or some other better solution? I’d like to keep the stock unit if possible, however I wouldn’t mind building my own “stereo” unit that would only consist of an AUX input, volume pot, 3 band EQ pots, and possibly some USB ports. Any help with a comparable solution to the adapter would be greatly appreciated.
Fat_OJ is offline
Old 11-14-2017, 11:23 PM
Super Moderator
JakeRobb's Avatar
Re: 2000 Camaro Monsoon to AUX adapter
I use this:
Amazon Amazon
As recommended here: https://thewirecutter.com/reviews/be...ry-car-stereo/
You can also have an aux in jack wired in to your factory head unit. I haven’t tried this, but if you join the Facebook group “Fbody Nation,” there’s a guy there named JR Rios who I believe does that for people.
JakeRobb is offline
