What's needed to run aftermarket HU with stock speakers???
Old 07-09-2005, 02:01 PM
Camarocracy's Avatar
My car does not have the Monsoon system, just the 4 speakers. I just want to run an aftermarket MP3 deck for now, plan on buying better speakers later on. What would I need to hook up an aftermarket deck with the stock speakers?
Camarocracy is offline
Old 07-09-2005, 08:07 PM
LS1 RULZ's Avatar
Re: What's needed to run aftermarket HU with stock speakers???
If your speakers are all 4 ohms all you need is a wiring harness to plug your new deck into the factory wiring. If the factory woofers in the doors are 2 ohms like the POS Monsoon system you may have a problem. Your typical HU can't power 2 ohm speakers. Not at loud listening levels anyway. At low to moderate levels you might be OK. If not the HU will probably go into protection mode and shut down.
LS1 RULZ is offline
Old 07-09-2005, 08:53 PM
cool_guy_j's Avatar
yeah, a wiring harnass will help you out. you'll be fine once you hook it up you shouldn't have a problem.
cool_guy_j is offline
Old 07-09-2005, 09:32 PM
moparman's Avatar
www.installdr.com
moparman is offline
Old 07-10-2005, 06:51 PM
Oddball's Avatar
If you buy the HU at a place like Crutchfield or sounddomain they give you the harness for your car and often the mounting kit.
Oddball is offline
Old 07-11-2005, 08:59 AM
rlax31's Avatar
I'm uding a aftermarket HU (Pioneer DEH-P77DH) and I have 2 ohm speakers.
No problems, sounds decent for stock speakers
rlax31 is offline
Rod Bender
01-01-2015 03:18 PM
Queens94z28
12-20-2014 09:11 PM
NED4SPD
09-16-2002 10:45 PM
WJH'sFormula
07-28-2002 04:51 PM
mjcent922
07-27-2002 12:42 PM
Quick Reply: What's needed to run aftermarket HU with stock speakers???
