CamaroZ28.Com Message Board
-   Car Audio and Electronics (https://www.camaroz28.com/forums/car-audio-electronics-12/)
-   -   URGENT...Please help, BOSE speakers (https://www.camaroz28.com/forums/car-audio-electronics-12/urgent-please-help-bose-speakers-6903/)
MJ_Z28 Aug 7, 2002 05:55 PM
There's a little box attached to the stock bose speakers, some kind of mini amp I believe. Inside the black box, there's a little coil of red metalic wire around a yellow cylinder. This piece has come loose one all but one of my speakers. There's some kind of adhesive (looks like tree sap) what is that stuff so I can get some and get my system working again.
Oh yeah, this is urgent cause I'm sitting here with the interior on the exterior of the car...and I'm running out of day light http://web.camaross.com/bb/frown.gif
Thanks,
MJ
MJ - 1995 z28
Eibach Lowering Springs, KYB Shocks, K & N Filter Kit, Borla Exhaust, Ground Effects.
LS1 RULZ Aug 7, 2002 06:30 PM
What you've described sounds like an iron core inductor. Possibly part of the amplifiers power supply (BOSE systems use powered speakers) or crossover. I'm assuming that what you have described is that the inductor is still connected but loose on the circuit board. If thats the case you can hot glue it back to the PCB.
MJ_Z28 Aug 7, 2002 06:39 PM
That's the one...what is hot glue? require glue gun? can I pick up at trac-auto, etc.?
Thanks for the feedback.
-MJ
LS1 RULZ Aug 7, 2002 07:10 PM
<font face="Verdana, Arial" size="2">Originally posted by MJ_Z28:
-MJ
</font>
You should be able to get a hot glue gun at any hardware store.
MJ_Z28 Aug 7, 2002 07:15 PM
thx for the info!!!
Edit: that fixed my problems.
Cheers,
-MJ
[This message has been edited by MJ_Z28 (edited August 08, 2002).]
