Twin 10" subs, what amp should I be using?
I have twin MTX Thunder 6000 subs in my car right now. They're 12ohm each. Really you're supposed to use them in a triad, but I'm only using 2 and only have room for 2.
Right now I'm powering them with an old as dirt Phoenix Gold XS2300, which is rated at 2 x 75W @ 4 ohms, 2 x 150W @ 2 ohms, or 1 x 300W @ 4 ohms bridge. Since my subs are 12ohm each I have them wired in parallel and have them running off the amp bridged. So I'm putting a 6ohm load on my amp right now, meaning each sub is each only getting less then 150 watts, I think 125 or so, I'm not doing the math!
I want to use a bigger amp, but not sure what I need. The subs are rated at 250 RMS, 500 Total. Keeping in mind that I'll be presenting the amp with a 6ohm load, what would you recommend?
I'm a noob at car stereo, I'm only a wiring expert
Rather than an a new amp I'd suggest new subs....
A pair of ED SQ10s would actually work well the amp you have, and I'm sure sound much much better
And that's probably cheaper than a new amp that still doesn't even meet the right ohm requirements
Fix the problem right not by band-aiding the real issue
Well I have the next model up and they rock
Although I do admit these are pretty low on the food chain for subs, they were simply the only ED sub that would work with his current amp, and they were a cheap way to fix the issue. (My assumption is the the OP didn't want to spend $$)
To the OP: You may blow your new amp as well with the same subs, as you are not providing the amp with the right ohm ratings
I would really think about new subs pretty quickly
brothaslide
Jan 9, 2016 12:11 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
