Subs Won't Play
Old Jul 24, 2002 | 10:19 PM
Vokabulis's Avatar
Post Subs Won't Play
I recently installed a new system with new head unit amp and subs. I had it working good but with only one sub playing and having to manually disconnect the power from the battery. I fixed both of those problems but now the subs wont play when I start the car. they will play when the is turned on but wont play when the engine is running. Could someone please give me some suggestions?
[]v[]ike
Old Jul 24, 2002 | 11:09 PM
robert_T's Avatar
Post
I had the same problem. When the engine is one, your HU gives off more power, If your HU has a separate volume for the subwoofers, try setting it to its minimum point. Then, when the engine is running, set it up little by little. This worked for me, hope it helps.
Old Jul 25, 2002 | 05:46 AM
LS1 RULZ's Avatar
Post
You've evidently made a mistake with your wiring somewhere. Go back and check and recheck everything.
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
