Stock Deck Taking a ****!!!!
Old Aug 29, 2003 | 09:10 PM
lt1_forever's Avatar
Angry Stock Deck Taking a ****!!!!
ok, i got my 97 SS back from the body shop today and when i went to turn on the radio it wouldn't turn on. So i checked the owners manual to see about the anti theft device on it. It said if it was actvated it would say lock when you turn the ignition, but it didn't say that. All its doing is flashing all the keys at the same time evey second. So i tried disconnecting the battery for a while to reset it and that didn't do anything either. Please help!!!!
PS: Its the deck with cassate player but with the 12disc hooked up to it
Old Aug 30, 2003 | 10:10 AM
notstock4long's Avatar
I don't know how to help, but I do have one of those stock decks if you want it. It is locked though, bu a dealer can fix it pretty cheap. Actually, a friend of a friend has the master code I think.
Good luck
Old Sep 4, 2003 | 05:21 PM
jakesnake123957's Avatar
Wink locked
Go to the dealer ,they can fix it for free.Jake
Old Sep 4, 2003 | 05:42 PM
firebirdude's Avatar
From
ls1.com FAQ thread.
Theftloc Bypass
1. Press and hold presets 2 & 3 for about 10 seconds until the first 3 digits of the display code are displayed
2. Write the numbers down.
3. Press the AM FM button, write down the next 3 numbers
4. Call 1-800-537-5140, when asked, enter 202107, press the “button” and enter the 6 digit code from the radio, you will get an unlock code, write it down.
5. Go back to the car, press the HR button and set the first 2 numbers, then press minute button and set the next two last numbers, press AM FM button, SEC should be displayed, turn on radio
To remove customers code, repeat step 5. you should see --- on radio face, the code is now out of the radio.
Update....
Try this. I found it on another forum.
The dealer quote listed on the thread does not work, but i was able to find one on the internet. The 5-digit code which did it for me was 06010. Before this a 2 must be entered for Pontiac, and an asterisk after, so when prompted after calling 1-800-537-5140, pontiac guys enter:
206010. The website where i got the dealer code is here:
http://www.google.ca/search?q=cache...en&ie=UTF-8
The site has been taken down, this is a cached version on google's server. I have saved a copy of it on my harddrive incase it ever disappears. I will post this same message on the other thread too.
maybe they change codes every now and then.
DirtyDaveW
Dec 1, 2016 05:37 PM
Roshambo
Sep 4, 2002 11:25 AM
CamaroKiddZ28
Aug 7, 2002 10:17 PM
CobraEatr
Jul 23, 2002 06:32 PM
