Speakers buzzing?
Old Dec 30, 2014 | 10:43 PM
Rod Bender's Avatar
Speakers buzzing?
In my 96 the rear side panel speakers have a buzz in them. It persists even when I substituted new speakers in place. The single Bose speaker at the rear is clear as are the door speakers. I have an aftermarket head unit that has been working fine for several years. It has been suggested the problem might be the wiring and not the head unit, but for both speakers? Any suggestions?
Old Dec 31, 2014 | 05:31 PM
GaryDoug's Avatar
Prominent Member
Re: Speakers buzzing?
Does this happen even with the engine off? If not, the problem could be with the alternator. Or a bad ground at the rear amp.
If it is always present:
I believe the amp for the sail panel speakers is in the rear subwoofer enclosure. Listen carefully at the sub to hear any slight buzz. If there is some, you might try replacing the Bose relay under the dash. Otherwise, it sounds like a defective amp.
Old Jan 1, 2015 | 03:12 PM
Rod Bender's Avatar
Thanks for the reply. Actually, I am getting the static anytime the fader control is turned to engage any other than the door speakers. The engine is not running.
Old Jan 1, 2015 | 03:18 PM
GaryDoug's Avatar
Prominent Member
OK then the alternator is not the problem. I suspect the amp in the subwoofer is defective. Sometimes that kind of noise is caused by old shorting electrolytic capacitors. I would open it up and look for capacitor "cans" that look swollen or cracked. Also check the connector for corroded pins.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
football4life
Oct 4, 2015 07:48 AM
Bxlt1
Sep 10, 2015 08:16 AM
tomfric
Parts Wanted
Jul 30, 2015 03:01 PM
