second battery ground
I'm going to add a second ground for my battery. Depending which battery terminal I get, I'll use all of the outputs that is has (like one 4 awg and one 8 awg and use the corresponding power wire for ground). For those who added a second ground, did you use the same gound or grounded at a different place?
Originally posted by Brian Demeter
Same spot. I added a 4GA ground cable from the top post, since my battery had both.
Originally posted by camaudio
just ground it, in a manner to handle the amperage your system is gonna draw, figure about 10 amps per 100 watts. and when you top the 140+ amp mark make sure its a 4g ground
