RF amp setup?
RF amp setup?
I need help setting up my amp. I have a T500-2 with a P2 duel 2 ohm 10 inch sub in a sealed Subthump stealth box. I have Pioneer Premier DEH-P400UB head unit running the door and sail panel speakers. Anyway, the amp is bridged pushing 300w rms to the sub.
Gain: I can do that.
Frequency: I can do that.
Crossover: LP, AP, HP Which one of these should I set it on? I'm guessing
LP since it's the Low Pass?
Frequency Multiplier X1 or X10? X1 is for 40 to 400 and X10 is 40 to 4000Hz
Slope Switch: 12db or 24db?
And anything I need to set on the head unit?
LP
X1
12db slope
However, you'd be best to experiment a little. You might like the 24db more, depending on your other speakers. It cuts the subs frequency at a quicker rate.
If your hu has sub settings, experiment with those too.
X1
12db slope
detroitmuscle
Jul 31, 2015 04:21 AM
