Rewiring '95 TCS switch harness for'97+ TCS switch
I am currently upgrading my center console in my '95 trans am to '97 trans am console. I noticed that the '95 switch has four pins and the '97 switch has 5 pins.
Is it possible to rewire the '97 switch to work in a '95, I didn't think they changed the TCS system from'95-'97 but I could be wrong. I ran some continuity tests on each switch and determined the wiring. Here is what I came up with:
I know that the '95 switch is a monetary switch so it is always open until pressed. When this happens the bulb turns off. I am not sure but I believe this is the case for the '97 switch, but I heard somewhere that the fifth wire, the grey wire is attached to the dashboard interior lighting.
For the '95 diagram I suspect that the brown wire and the purple/white wire are the light bulb circuit and the black/white white wire and the brown/ white wire are the switch circuit.
For the '97 diagram I suspect that 1 and 2 are the light bulb circuit and either 3 and 5 or 4 and 5 are the switch circuit.
Does anyone have an official wiring diagram for the ''95 and '97 switch. and are both bulbs 12v?
Who has done this rewiring before, and how do you do it?
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
detroitmuscle
Jul 31, 2015 04:21 AM
