Replacing speakers on Monsoon system
I have a 98 Z i am assuming I have a monsoon system. I replaced the HU with a Pineer premier, and I want to change the front 4 speakers ( 2 in door , 2 in back seat pillars) the 2 speakers in the hatch are in good shape still. Ive heard the stock speakers have a 2 ohm load, and most aftermarkets have 4 ohm load, how can I installed aftermarket speakers without losing half the power though the extra 2 ohm load?
front door speakers
If you use a 4 ohm speaker in the front doors with the Moonsoon system, the
sound output from the 4 ohm speakers will be less than the 2 ohm speakers so when you turn up the volume, especially bass driven music, you stand an excellent chance of pushing the amplifier into "clipping"....clipping will damage the speakers sufficant to require their replacement. Either go with the OEM 2 ohm Delco or get a different amplifier friendly to 4ohm speakers. |
Re: front door speakers
Originally posted by EuropaCamaroMod If you use a 4 ohm speaker in the front doors with the Moonsoon system, the sound output from the 4 ohm speakers will be less than the 2 ohm speakers so when you turn up the volume, especially bass driven music, you stand an excellent chance of pushing the amplifier into "clipping"....clipping will damage the speakers sufficant to require their replacement. Either go with the OEM 2 ohm Delco or get a different amplifier friendly to 4ohm speakers. |
THANKS ALL
