Remote Start
Old Jun 27, 2004 | 05:50 PM
PDCamaro318's Avatar
Remote Start
Is remote start worth it to install on a Camaro or should I just get a great security system without the remote start? I'm looking at the Clifford Matrix RSX 3.5 w/ remote start but I could just get a different system in the Matrix line without remote start.
Old Jun 28, 2004 | 09:22 PM
Javelin3o4's Avatar
i got the rsx3.5 on my firebird right now, i also have one on my daily driver. works great, extended range + alerts you on the reomte when the alarm is triggered. the matrix 2.5 is the same thing just no remote start.
Old Jun 28, 2004 | 11:41 PM
my question though is the remote start worth the security downgrade bc of having to disable VATs.
Old Jun 30, 2004 | 12:47 AM
JJ's95B4C's Avatar
You don't necessarily disable VATS. You just place a resistor in the wiring of the remote start equal to that of the chip in your key. If you tried starting it with the wrong key it would not start.
Old Jul 3, 2004 | 01:12 PM
Oh ok thanks man. My only other question is how does remote start actually work. Like what prevents someone from just stealing the car while it is remote started if I dont get there in time or if I accidentally start the car. If anyone could help that would be great.
Old Jul 3, 2004 | 01:28 PM
Javelin3o4's Avatar
when you install remote start, you hook a wire to the brake switch and to a pin switch under the hood, if the hood is opened while the car is remote started it shuts off the car, if someone gets in the car and the brake is pressed before the key is turned to the "ON" position it shuts down the car.
Old Jul 3, 2004 | 08:35 PM
so would I still need my key to move the vehicle? and like i said what prevents someone from stealing my car?
Old Jul 4, 2004 | 12:49 AM
Javelin3o4's Avatar
Well you need the key in the ignition turned to the on position to unlock the steering wheel, and since it has a VATS system even if they did manage to unlock the wheel once they press the brake to put the car in gear the remote start will shut down and turn the car off, and since the key is not in the ignition to send the VATS system the required resistance it wont stay running.
*If the brake is pressed at anytime or the hood is opened anytime while the car is remotely started and the key is not in the ignition the car will shut off.
Old Jul 5, 2004 | 12:10 AM
oK thanks so much for all the help. i think i have all my questions answered now. i'm not used to the remote start stuff How do i measure the resistance of my VATS? I think its been told before but I dont remember how. sorry for the problems guys
Old Jul 5, 2004 | 03:47 PM
Javelin3o4's Avatar
set your DMM to Ohm's and touch each side of the resistor in the key with the probes.
Old Jul 6, 2004 | 11:00 PM
Thanks so much for your help man. I'll be sure to update when I get the system installed with a review.
Jan 23, 2015 01:13 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Rod Bender
Jan 3, 2015 03:15 PM
Jeff1904
Jan 3, 2015 12:00 AM
BAD 97 WS-6
Sep 11, 2002 01:45 AM
