PAC OEM-1
Is this the only place to buy one?
http://www.affsave.com/pac.htm Or are there any cheaper ones out there? Thanks ------------------ Proud new owner of a 1997 Z-28 M6!!!!! Let the fun begin! --------FOR SALE--------- 1989 Blue Iroc-Z Edelbrock Headers, High-flow cat, Fastchip, Airfoil, K&N's. |
Thats the cheapest I've seen. A place called Tune Town (or something like that) used to sell them for $80. You might have better luck buying a used one. Try asking over at LS1.com
These guys have the box for $25, but haven't found the 2 interface cables I need yet.
http://www.audiowarehouse.peachhost...._PR2644971.htm I am looking to add a sub amp, and will be needing: 1) the PAC OEM-1 unit itself 2) The AMP-RCA cable for RCA outputs 3) The ADD-GM32 cable to interface to my factory Bose HU. Good luck, Thomas. ------------------ '96 Z28 6-speed Completely Stock (for now) |
You'd better check that Thomas. I think you need the ADD-GM21 for the BOSE interface. Not the GM32.
Ya know, I was a bit confused on that; because I found info that said the ADD-GM21 was for years up to 94 (or maybe 95?) and the ADD-GM32 was for my '96.
Is this not correct? If not, I'm glad I found out now instead of after I ordered them http://web.camaross.com/bb/smile.gif Thomas. ------------------ '96 Z28 6-speed Completely Stock (for now) [This message has been edited by Stoopalini (edited July 18, 2002).] |
I just did a bunch of searching, and you are correct. It's the ADD-GM21 cable I need.
Thanks for pointing that out. FYI: Check out this Sub Install using a PAC OEM-1 unit page I found; it looks like some good info. Thomas. ------------------ '96 Z28 6-speed Completely Stock (for now) |
