How do i run my power wire
Where is there a good spot to run my power wire through the firewall. Is there a good spot on the pass side to drill a hole or is there a hole somewhere already that i can use
Re: How do i run my power wire
pull the pcm out and lay it on the cowl. there is a 1.5 inch grommit right there. Just make sure it stays seated in the firewall when you push through it because it could let water in.
