CamaroZ28.Com Message Board
-   Car Audio and Electronics (https://www.camaroz28.com/forums/car-audio-electronics-12/)
-   -   HELP!! Having trouble on amp install (https://www.camaroz28.com/forums/car-audio-electronics-12/help-having-trouble-amp-install-6841/)
Snake Slayer Jul 28, 2002 07:09 PM
OK, my car is a 00 ss, I installed an aftermarket headunit a couple of days ago, today I,ve been trying to install my amp and an MTX thunderform, all the wires are ran the amp has power, I even tried a different set of RCAs but still nothing. I don't need the PAC with an aftermarket head unit do I? Should my remote wire be hooked to the head unit I'm using or the adapter harness? Sorry so long I'm just pulling my hair out trying to figure this out. Thanks for any help.
LS1 RULZ Jul 28, 2002 07:32 PM
NO
Run the remote lead directly from the HU to the amp.
Snake Slayer Jul 28, 2002 08:33 PM
Thanks LS1 Rulz. Well, I've got the remote hooked to the head unit but still no sound. I tried using another amp but the power light on it just blinked, no sound. Anybody else have any suggestions, I really don't want to take this thing to a stereo shop but it's starting to look that way
sleeperZ96BT Jul 28, 2002 08:36 PM
check your ground, if its not grounded well it will sometimes flicker or not come on at all (my problem).
brian
megabass Jul 28, 2002 08:57 PM
Well, if you have power to the amp, it sounds like a signal or speaker wire problem. If it's a multi-channel amp, make sure the RCAs are going to the right set of inputs. Also check your speaker wire leads to the terminal on the box and then from the terminal to the sub itself. Other than that, it's hard to tell without more info. Good luck.
CrAkD X 95TA Jul 29, 2002 07:18 AM
what kind of head unit do u have? some headunits require you to activate the preouts.
tygreman Jul 29, 2002 12:39 PM
Are you installing subs to the amp or the factory. If its factory you have to bypass the amp by the spare tire.
Black 00' SS
(1) Pioneer 480
(3) 12" Solobaric L7s
(3) Earthquake 200Ds
(3) Marine Batteries
(1) 6 Farad Cap Bank
(2) 15" Compression Drivers (Loud AZZ Highs)
(1) Broken Trunk Latch courtesy of the L7s
C.A.N.I.
Conastant And NeverEnding Improvement
