Easy Amp Question
Old Sep 17, 2002 | 01:33 AM
Lions3's Avatar
Easy Amp Question
I have an MTX 4250 (I'm changing this to a 6000..Not enough!). Anyways, I was wondering how I get it bridged (It's a mono amp! WTF!) and have a 2 ohm load with 2 10" SVC subs (40hms each, wired in parallel..right?).
The reason I mention bridged, is because Sounddomain.com says it puts out 350 watts RMS @ 2 ohms BRIDGED. I also thought it was odd how a mono amp has two speaker outputs.
Anyways, a wiring diagram would be nice. Merci beacoup.
Old Sep 17, 2002 | 01:46 AM
x7x7's Avatar
Those aren't two channels. That's one channel, the positives are connected together and so are the negatives. It just helps make it easier to wire stuff. All you need to do it wire the positive on each sub to the positives on the amp and the negatives on each sub to the negatives on the amp.
A mono amp never has more than 1 channel but it may have more than one set of terminals for that channel. Bridging is a function of a multi channel amp.
Old Sep 17, 2002 | 09:25 AM
Lions3's Avatar
Okie dokie. That's what I assumed, but there wasn't any definite info in the install guide.
So basically now I have a 2 ohm load on the amp with the 2 4 ohm SVC Subs? Shweet
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
NewsBot
Jan 8, 2015 11:29 PM
ChrisFrez
Dec 15, 2014 03:09 PM
