Audiophiles......What Subs For My Truck?
#17
#20
Guest
Posts: n/a
Ah, a thread where I can shine
Check out this website for some boxes for your truck. Subthump.com
12's are as large as you're going to be able to fit in your truck. 12's will play lower and louder than 10's, so if you play a lot of rap 12's are probably what you want.
Any commonly known name brand sub that costs from $50-$100 will likely sound very similar to another in the same setup. If you really want a good deal on some subs and don't care what they look like, check out the EHQS 12's by Elemental Designs. $25 a piece, I would put them up against any Kicker Competition, JL W0, RF Punch, any mainstream entry level sub on the market, and they'll perform as good or better.
Whatever subs you go with, make sure you get the correct impedance to match up to your amp. I looked up your amp and you need subs that are either 2 ohm, 8 ohm, or 4 ohm with dual voice coils (DVC). This is important, as most subs are just plain 4 ohm and if you use those you'll end up only using 1/2 of the power of your amp.
#21
jackpawt883
09-10-2015 08:53 PM
