Any 6.5" with midbass? or 6*9's??
Old Aug 31, 2003 | 10:02 PM
hellostop's Avatar
Does anyone make a 6.5 with decent midbass, what if I go with some high end 6*9's and back with a sub?
Old Aug 31, 2003 | 10:36 PM
firebirdude's Avatar
Adire Audio Koda gets my vote. If those are too expensive..... look into the Kicker RMB6's.
Old Sep 1, 2003 | 06:57 AM
LS1 RULZ's Avatar
Just say NO to 6x9's
Old Sep 1, 2003 | 10:30 PM
hellostop's Avatar
mid bass
$80 is cheap if the Kodas deliver.
What is a recommended tweeter that has the correct impedence ?
How much power @4ohms?
Old Sep 2, 2003 | 11:44 AM
Re: mid bass
That is $80 EACH. If you want a pair..... then you have to buy two. Tweeter? If you are trying for a component set, then buy the component set.
Old Sep 4, 2003 | 01:22 AM
bt96ss's Avatar
you can make any quality midbass sound good. If you build a enclosure for the speaker, deaden the door or rear wall, use some polyfill and put some power on them. And when I say power I mean more than 50 watts rms. A speaker put in the hole, running off a radio will very seldom deliver good midbass. Example in the rear I put dynamat extreme on the wall where the spk goes dampening any vibes the wall would catch. I put polyfill all in the wall then installed the speaker. I did one this way and just installed the other speaker in the uprepped side and there was a world of difference. The prepped side had good midbass and a fuller sound. I did the same up front but I buit enclosures out of the factory rain guards. My midbass is so much better I can turn my subs off and still have good bass.
Old Sep 4, 2003 | 10:04 PM
hellostop's Avatar
Is it possible to build an enclosure behind the front doors factory location? without messing up the window operation?
When you say 50 watts, is that at 2 ohms or 4?
Old Sep 5, 2003 | 08:00 AM
bt96ss's Avatar
yes it it possible. You just have to build a small sealed chamber not like a huge box in the door. You take the factory rain guard and use some fiberglass and make a speaker baffle out of it. At leat 50 watts 4ohm per side. I personally have 200 watts a side.
Future_Z_Owner
Oct 24, 2007 06:54 PM
eagleknight97
Apr 26, 2006 03:47 PM
BradcTA
Mar 21, 2006 06:02 PM
zzman
Mar 11, 2005 11:40 AM
onlyforyou
Jan 5, 2004 08:26 AM
