Amp
Old Nov 15, 2002 | 11:15 PM
JDud24's Avatar
Amp
I have the stock Bose Head Unit and all stock speakers in my 95 camaro, and im getting a RF punch 300S amp, and an Infinity Kappa Perfect dual 4 ohm 10 in. sub. I heard there is some special wire i need to get to plug up my amp to the head unit, is this true or would the regular installation kits work? Also i heard b/c its a stock head unit it wont make the sub sound as good or something, and that i should get an aftermarket head unit, is this true or will the stock work fine? Also what are all the wires i will need to hook this up, i have someone to do it, i just have to buy all the wires and im not sure which i'll need. Thanks~
Old Nov 16, 2002 | 07:30 AM
LS1 RULZ's Avatar
The easiest way to add an amp and sub to the stock stereo is by using a PAC OEM-1. Since you have the BOSE system you'll need the GM21 and AMP-RCA harnesses for it. You'll also need large guage power and ground cable as well as a fuse and holder. You'll also need some RCA cables to attach the amp to the BOSE HU.
RUENUF
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Bobczar
Oct 23, 2015 11:22 AM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
NewsBot
Jan 8, 2015 11:29 PM
