More Toyota woes... with Lexus now.
I have been watching closely as Toyota struggles and strains to keep the Lexus name out of their current drive-by-wire problems, even though one of the very first reported casualties of that problem was in a Lexus ES. Well, apparently they won't be able to put the squash on an independent magazine's latest column, huh?
Don't Buy: Safety Risk--2010 Lexus GX 460 - Consumer Reports
"Consumer Reports has judged the 2010 Lexus GX 460 SUV a Don’t Buy: Safety Risk because of a problem we experienced during our standard emergency-handling tests. When pushed to its limits on our track’s handling course, the rear of the GX we bought slid out until the vehicle was almost sideways before the electronic stability control system was able to regain control.
We believe that in real-world driving, that situation could lead to a rollover accident, which could cause serious injury or death. We are not aware, however, of any such reports.
All four of our auto engineers who conduct the test experienced the problem in an exercise used to evaluate what’s called lift-off oversteer. In the test, as the vehicle is driven through a turn, the driver quickly lifts his foot off the accelerator pedal to see how the vehicle reacts."
I guess when it rains, it pours.
Toyota... Suxtabeya.
Consumer Reports has a lot of influence on a good number of vehicle buying decisions. A "Don't buy" is serious.
Did anyone see the video = http://jalopnik.com/5515879/lexus-gx...dont-buy-award
I've given up on Consumer Reports when it comes to cars. Because the SUV can't take a hair pin turn like a Corvette you shouldn't buy it? Yeah, it looks like the stability control sucks but if you are driving like a normal person you shouldn't have to worry about it. I've never even owned a car/truck with stability control until our Equinox.
So by CR's logic, should all other SUVs/trucks that don't have stability control also be a "Don't buy"
I think there are modern airplanes (military) out there that actually border on being unstable in steady flight, and it is the sophisticated fly-by-wire and brains of the system that allow them to fly safely with constant adjustments being made, faster than the pilot could do. Maybe I'm nuts, but I think I read that this is the case (or maybe I read that such things are coming).
I wonder, would CR rate any Porsche 911 up to the late nineties a "don't buy"? I think the term "lift throttle oversteer" was pretty much coined for that car.
Generally, I'd say that making any sudden transition in the middle of a turn is not really a good idea unless you know what you are doing, regardless of the vehicle.
The point is that with electronic stability control, the vehicle should not be doing this. Someone who may just assume that the computer nanny will save them from their own stupidity (or rapid avoidance maneuver at speed) will get a surprise.
Outside of that I guess the question is, is this vehicle documented to be more prone to oversteer or is the oversteer significantly greater compared to others in its class? My initial guess would be, probably not.
I certainly have no love for Toyota but I would agree that 99.99999% of the population would never experience this since they aren't going to be pushing a vehicle like that to its handling limits.
Back to the point though, try driving a z06 (or heck, anything at those power levels) with the nanny controls off in wet weather. You're going to slide all over the place unless your foot is extremely sensitive. At this point, most high end sports cars already rely on aids to tame them. Think you've got the guts? Try driving a z06 in half an inch of snow with the nanny gone!
Until GM puts a waiver on a Corvette buyers agreement that you are not allowed to drive it in the snow or cold weather, it is expected that someone could go out and drive it in a glazing of snow and ice. The only way to make it anywhere near possible is with those nanny systems, and it's only going to get worse. Heck, look at Toyota and how their "drivers" seem to have forgotten how to operate their vehicles...
I'm annoyed that all these advanced systems even exist. They add complexity, add cost, add weight, increase maintenance costs when they fail, and I believe they make drivers more complacent and therefore less safe in the long run. Just like drive by wire, when complexity is added, problems occur. What's wrong with simple and predictable mechanical systems? I don't understand why our world has become obsessed with making everything electrical/computerized! And one more thing.... sorry for the rant
Originally Posted by El Duce
Well I don't know about you guys, but I routinely take out my Lexus GX to auto-x events.
I think the idea is not that this would be run like a Corvette or whatever, but that it would happen in an unexpected emergency maneuver... making the situation potentially worse.
you sure showed me by thinking of the most extreme example you possibly could and stating it sarcastically to make me look like an extremist moron. If I cranked my engine by hand every morning, I'd welcome an electric starter motor. However, I've never owned a vehicle with stability control, I know it exists, yet I don't miss not having it in my normal every day vehicle. I see it as being more complexity and cost than is required in a vehicle that isn't designed for extreme performance. I also don't understand the benefit of having a computer translate the position of a pedal into the motion of an electric motor attached to the throttle. A steel cable attaching the gas pedal to the throttle with a return spring is more reliable and has a much better outcome in case of failure. If you disagree with my opinion, that's fine, but don't insinuate that I'm a fool for having it.
Then I bought a set of Bridgestone Blizzaks and had them mounted. A few days later, I repeated the same test, and could not for the life of me get the stability control to engage.
So, I'd suggest that if you're worried that stability control is going to kill you, you get some better tires.
