bmw to unveil 306 hp straight six engine in geneva
Re: bmw to unveil 306 hp straight six engine in geneva
Can this engine really be that much cheaper than the old 333hp 3.2 straight six BMW used to use in the e46 M3s?
Its kind of unusual (and disappointing) to see BMW going the turbocharged route. They have been building nothing but high tech NA engines for awhile now.
306hp... that's a familiar number.
Oh ya... that's exactly the amount of HP the IS350 has been using to mop the floor with the 3-series in acceleration tests ever since it came out.
Did BMW start feeling the heat that the 'old man's brand' was leaving their 330 in the dust from stop lights?
Interesting to see they had to (or maybe just wanted to?) go biturbo to produce the same power with the same number of cylinders that Lexus was doing N/A? (albeit with half a liter more displacement)
They probably had their reasons for going turbo.
Looks like a nice motor.
I'm actually considering the 3 series along w/ the Camaro for my current car's replacement. Two totally diff. cars I know, but it's what I like. W/ this 3.0 bi turbo this car will truly hall, too bad it will costs over $43k, which isn't bad, but that's just for beginers. I wouldn't expect this car to have all the options, as the Germans are typically quite liberal, knowing that you'll pick the latest and greatest tech which in turn jacks up the price sky high. Once you drive this car though, you can't get enough.
from what Ive read the torque curve is friggin mountainous by 1800, and stays steady all the way to 5kish. its also supposed to be more efficient than the old 333 horse motor
If they are developing the same amount of power as the Lexus is NA then the turbocharged motor either:
1. Has a lot less displacement
2. Makes a lot more torque
3. Has less displacement and makes more torque
In this case it turns out to be option 3.
And for comparison, the new straight-six biturbo weighs about 70 kilos or 158 lb less than an approximately equally powerful eight-cylinder normal-aspiration engine displacing 4.0 litres.
That it is.
So to be competitive in power, they needed a turbo.
The next Mini will also be turbocharged. One theory that I've seen written about is that turbos+direct injection will be a more efficient, cost effective way to get high horsepower than larger displacement. In addition, an inline engine is easier to turbocharge than a V-engine. So the stars sort of lined up for this.
The 306hp number will be a DIN number, and it works out to a nice, round 225KW. Since it's a "technology announcement", I would think that an SAE-certified number for an actual production model would vary by a little bit from that. The Lexus 306hp is SAE certified, and works out to 228KW.
So I think the short answer is that 306 is a coincidence.
Originally Posted by RussStang
Neither is an LS2.
Neither is an LS2.
That is how I took Todd's comment.
