200mpg car?
200mpg car?
so here it is 230 miles to a gallon i think its pretty neat. here is my thing though if this can get 230 why cant a normal car do at least 50 on highway.
http://green.yahoo.com/blog/ecogeek/...r-in-2010.html
I'd say that the number one reason is power and weight. If we cut the power in half and the weight by a thousand pounds on most small cars, they'd probably get close to 50 highway. But people don't want slow cars and with today's safety standards piling on the pounds, it nearly requires exotic materials to lose weight where it's possible.
"But, since it does have four wheels, it will have to meet all of the normal safety regulations for cars."
Max speed of 75mph... ouch
I wonder what the cost of it will be. This article is a few months old, but look at the materials they are using to build this car.
http://carsworld.northglow.com/volks...uel-efficient/
I am a designer on the 787 so I am quite familiar with lightweight materials.
Aluminum is relatively cheap compared to the other metals and could be easily used. The others have a bit more of a supply constraint right now.
hell if i could get a 50-60 mpg in a conventional car and the max was 75-80 i go for that in a heart beat
I regularly hit 80 going with the flow of traffic. Plus if the MAX is 75, then it likely will take a while to even hit 60, unless it's 75mph limit is computer programmed in...
i dont know of any speed limit higher then 70 miles an hour and i can tell you for a fact that at 75-80 mph my cobalts mpg start to drop like a rock.
well its looking like your not going to get to much more out of things with out some sacrifice along the way. im pretty confident in saying that having a max of 75-80 is more then enough even if its a gearing issue and takes time to get to speed in most situations.
