which car handles better?
I'd vote for the RX7, but I'm guessing. My guess is based on my impression that the engine is located further back in the RX7, and that adding a bigger, heavier engine would therefore have a less-adverse effect on weight distribution.
It would, of course, vary greatly from car to car, as I'm sure that no two LS1-powered RX7s are exactly the same, nor are any two V8-powered Miatas exactly the same. We're talking about significant modifications, after all! Not to mention the fact that you didn't even specify what V8 would be in the Miata.
I'm not aware of a convertible RX7, but I could be wrong.
From: Knoxville, Tennessee/Mooresville, N.C./Phoenix, AZ/Bristol, TN
The second gen's(1986-1992) were the only ones that you could get as a convertible. After that(1993-2002) every one was a coupe.
I'd vote for the RX7, but in either case you'd need to be very sensitive to weight... in fact I wouldn't be surprised to find that the stock versions of those cars was faster around a road course than the front heavy V8 versions.
Maybe a small super light V8... like the Hyabusa V8 from the Radical SR8
Pushrod engines have lower CoG's than OHC engines of similar displacement and layout... but I'm pretty sure that the 2.6L twin-rotor twin-turbo rotary in an RX7 is smaller and has an even lower CoG.
