Who would be interested in a different headlight assembly for 93-97 Camaro's?
#744
meh, i just don't think circular headlights belong on LT1's... doesn't go with the front end at all. they go with ls1 front ends though because it's smoother.. and I think 3 lights make it look a little busy, but that's just me.
#745
Why not just lock this thread..... And start a new one if any information is available..... This is like beating a dead horse... The race is already over......
#746
Beating a dead horse would be making comments like this as we already have dedicated half the thread to it at this point. You can be in disbelief that FocuzTech will ever make these, and give up waiting for them and go for something else, or you can accept like myself and others have that they will make them even if we do have to continue to wait for them. If you are "NOT" interested in this different headlight assembly for the 93-97 Camaro's, then this thread is not where you should be posting.
#747
#748
#750
Back on page 29; this is what they will be basing them off of.
Folks-
I am sorry we have been so quiet...not an indication of how busy we are.
I just picked up our Camaro from our plastics manufacturer after doing quite a bit of measuring and design work. The benchmark for "appearances" sake is the picture above. We are designing the bezel and housing to look very similar to whats pictured above. There are numerous challenges with this as the height of the headlamp opening on the Camaro is much smaller...shorter. In addition the headlight mounting bracket that is part of the front fascia does not afford alot of mounting options. Also the trailing edge of the hood, at the headlamp opening, is cut back which makes setting the modules fore and aft abit of a challenge...again the goal is not cutting and drilling.
At any rate, we have arrived on a preliminary design (pending actual adjustments during test fit) and expect to have a final figure for tooling, engineering and molding very soon.
Folks-
