What should I use to glue rubber seals on 1999 Camaro Headlights?
So I bought some Projector beam headlights on ebay, they look quite nice however the seals came off real easy since they just seemed to be on with double stick tape. I went to auto zone and they gave me the sealant glue which was a bad a idea because it just made a big mess and the dry time was 1 hour was was way too much. Anyone know any glue I can buy the will be cement hard and strong, dries quick and should work for these headlights?
Re: What should I use to glue rubber seals on 1999 Camaro Headlights?
I have a friend who puts projectors in headlights, I talked to him about them the other day. He showed me that he was using caulking used to anchor bolts into concrete. He picked them up at walmart, seemed fairly effective.
are you talking about the seals between the clear lens and the housing, or the black rubber strip around the light? i used superglue for the black rubber strip. just make sure you dont let any go out from under the rubber, and itll work fine.
12-04-2014 11:56 AM
12-01-2014 08:08 AM
