CamaroZ28.Com Message Board
-   Appearance (https://www.camaroz28.com/forums/appearance-34/)
-   -   What is this inside the door? (https://www.camaroz28.com/forums/appearance-34/what-inside-door-888693/)
Displacement up Jan 18, 2021 10:31 PM
Does anyone know what these little panels are called that are threaded and bolt to the hinge? Going to definitely need some new ones, but not sure where to look... or how to get these out.
https://cimg6.ibsrv.net/gimg/www.cam...c53861ac52.jpg
GaryDoug Jan 18, 2021 11:33 PM
Re: What is this inside the door?
I'm not sure what they are called but if I remember correctly they are just a small steel plate with three nuts attached. On my 98, they were removable from inside the door. Obviously your car is older, with steel doors, unlike the composite ones in my 98. What year?
Injuneer Jan 19, 2021 09:10 AM
What year is the car?
When you posted 4 years ago you mentioned a 1974 Camaro.
Displacement up Jan 19, 2021 11:19 AM
yep, it is the 1974. I think its called a hinge plate, but nobody seems to sell them. Or know of a good way to remove them. Everyone else I've asked has had problems with it rusting too but no solution.
Injuneer Jan 19, 2021 11:47 AM
Can you pull the part out? If it's as simple as what Gary describes, should be easy to fabricate. Didn't see anything similar at the usual classic car parts outlets.
Displacement up Jan 19, 2021 03:00 PM
it will require cuttingcand welding inside a place where I dont really think I can get that to fit. Would it be worth it to rip the door skin off, and reskin it? Might be what I need to do to get in there.
