VFN Hood Question...
I was wondering if it had holes for the underhood insulation on the 93-97 hoods? Our stock hoods leak water = no good for the opti and in general. Unless their hoods took out those imperfections?
A factory under hood insulation would look mighty stupid under a cowl-hood.
As far as I know it doesn't have any provisions for it anyway, theres no cross frame like the stock hood. |
I know it doesn't help exactly, but my ASCD cowl hood has no provisions for the insulator.
Well I don't care how it looks when it is protecting my engine from water. I don't get how it would look any more or less stupid under cowl hood. The hood does nothing, it is for show.
I suppose I can use autobody sealant and paint if the VFN hoods have the same problems as the stock. |
Do the stock Camaro hoods leak? Never noticed that problem on my Firebird hood, stocker or the WS6 hood. Relying on the insulation to trap water would seem to be a bad idea. If your hood leaks, fix the leak, don't try and cover it up with insulation.
never noticed the water leak problem on my stock hood, or my new vfn... i didn't know water could go through metal and/or fiberglass hoods... i guess if you open the hood in the rain, you might get a small leak... not sure why the stock insulation is there int he first place.
Originally Posted by Crows89RS
(Post 5206064)
My 2" cowl hood from VFN does not have provisions for the factory insulation. I thought of it as just another weight savings.:D
Yes, they leak from 2 places - where the plastic hood vent inserts slide in and in very small cracks and holes around the metal part of the removable hood vents, only not so bad on the latter. But they are still 2 separate pieces on the hood, therefore they have no seal. If you look on the inside of the insulation, you can see where the channels are that go right to the edges of your windshield and expel out the drain holes. I guess I'll just be using sealer and paint.
And it's hardly for heat, this is a myth that your paint will bubble from heat without the insulation. :nuts: |
Originally Posted by MarcR94v6
(Post 5207416)
And it's hardly for heat, this is a myth that your paint will bubble from heat without the insulation. :nuts: And I think it'd be easy enough to remove the inserts and put a bead of silicone around the inside to seal the moisture out. A couple dollars and maybe a half hour of your time would do it. |
Originally Posted by shock6906
(Post 5208160)
I can't see what else it would be for.
Insulation is also used to cut down unwanted noise. |
