Use gas to remove emblem glue???
I'm putting a new Z emblem on the side and just wondering if using gas to remove the old glue from the paint will damage it. I would rather use something else if it were not as harsh on the paint. Thanks!:D
Sure...you can use gas. Just have someone lined up to repaint it in the spot you used it. :)
You something less agressive. I would try a blow dryer and a little bit of rubbing. |
Scratch-X
No kidding, it worked for mine. |
Re:
Use bug and tar - Something maybee that removes tar, gum something like that use. I used bug and tar and it did not do anything to my show car - thats right SHOW CAR. bug and tar try
Us goo off.
Gasoline works;). So does brake cleaner!!:D I've used these on paint before and never noticed the paint go bad?:confused:
re:
Dont use brake cleaner. I saw people use brake cleaner before and it damaged there paint. Then again. The kid that did that painted his whole car with a brush and 1 gallon off light blue paint by hand -
Alright thanks guys! :thumb: BTW who paints their car with a brush???:no:
